Stranica 3 od 20 PrvaPrva 1234513 ... PosljednjePosljednje
Prikaz rezultata str. 21/198
Tema: Titlovi
  1. #21
    Urednik
    Član od
    Jan 2008
    Poruke
    40
    6
    Pohvaljen 0 puta u
    0 postova
    Odg: Titlovi
    Hvala vam puno prijatelji,
    Trenutno sam zauzet sa drugim poslom ali cu ovo probati poslije, i ako ovo uspijem onda trebam to staviti na dvd to moram isto potraziti da vidim kako to ide, radio sam filmove bez tila ali sa titlom nisam.
    Puno hvala,
    Mrki_NL
  2. #22
    josip11
    Gost
    Odg: Titlovi
    samo ga sprži sa nerom ako proradi!
  3. #23
    Član od
    Jul 2007
    Lokacija
    Poruke
    8,806
    2,893
    Pohvaljen 7,716 puta u
    2,622 postova
    Odg: Titlovi
    Pozdrav
    Probaj sa BS Player PRO v2.26.956
    Ever since the very beginning in the year 2000, the BS.Player™ has been one of the world’s most popular video player. It is popular for many reasons, one however should be pointed out: BS.Player™ is the first movie player ever to enable its users to focus on watching the movie instead of dealing with poor computer capabilities or running around looking for a proper setting and codec. Also, it has very low CPU and RAM requirements.
    What does the BS.Player™ 2.26 PRO has to offer?
    * Customizable Equalizer
    * Support for Capture and Tuner devices (and Teletext support)
    * Capture Video from capture device to file
    * Integrated subtitle editor
    * Network file buffering
    * Support for Flash playback
    * Improved subtitles
    * Improved VMR9 support
    * DVD support (codecs required)
    [logged]Download:
    http://rapidshare.com/files/82809830...ngual-CORE.rar [/logged]
    Nasa mreza: SerbianForum.org :: TitloTeka.com :: MedioTeka.net :: PornoZabava.com i brojni drugi ...
  4. #24
    ***Diomond Members***
    Urednik
    Član od
    Jul 2007
    Poruke
    1,883
    326
    Pohvaljen 826 puta u
    366 postova
    Odg: Titlovi
    Po meni ja BSplayer najbolji player za filmove. To radi samo od sebe ko media player classic
  5. #25
    josip11
    Gost
    Odg: Titlovi
    samo što za njega kažu da je spaywer player?
  6. #26
    Urednik
    Član od
    Jul 2007
    Poruke
    1,883
    326
    366 postova
    Odg: Titlovi
    Ma meni odgovara. Imam staru verziju 1.22. Ona je jedna od boljih
  7. #27
    Urednik
    Član od
    Jan 2008
    Poruke
    40
    6
    Pohvaljen 0 puta u
    0 postova
    Odg: Titlovi
    Mix,
    Ovo upustvo sto si mi dao je OK, instaliro sam FFD show i sad mi titl na WM11 radi na onaj nacin kao sto si mi ti napisao, e sad trebam ton staviti na DVD, radio sam przenje obicnog DVD il ovih DVD-ova koje sam skinuo uz pomoc ovog sajta, ali nisam do sada radio filmove na koje treba ubaciti titlove. Imali neko mozda neko upustvo da mi pomogne da snimim DVD na koji treba ubaciti titl.
    Hvala,
    Mrki_NL
  8. #28
    Urednik
    Član od
    Jul 2007
    Poruke
    1,883
    326
    366 postova
    Odg: Titlovi
    Evo ovdje skini DVDflick: http://www.crosatelite.com/forum/index.php?topic=4037.0
    1. Nakon šta ga otvoriš odaberi Add title i odaberi film
    2. Klikni na edit title i idi na kraticu subtitles
    3. Klikni add i odaberi titl
    4. Klikni na Edit i tu si namjesti font i pod Language odaberi Croatian, a pod Char. Set MacCroatian
    5. Klikni 2 puta na accept i u glavnom prozoru, dolje na dnu odaberi destinaciju na koju ce ti izripati film u dvd
    6.a) Takoc‘er u glavnom prozoru klikni na project settings i pod kraticom Burning stavi kvacŤicu na Create ISO image
    b) Možeš odmah nakon rippanja i spržiti film tako da odabereš Burn project to Disc.
    7. Klik na accept i klikni na create DVD.
    8. Nakon što završi sa ripanjem u folderu ce ti se nac i ISO datoteka koju sprži sa Nerom. Ili ako si odabrao Burn project to disc ce ti automatski spržiti film (naravno moraš staviti prazan DVD u pržilicu)
  9. #29
    josip11
    Gost
    Odg: Titlovi
    ¨bravo @mix (p:)
  10. #30
    Urednik
    Član od
    Jan 2008
    Poruke
    40
    6
    Pohvaljen 0 puta u
    0 postova
    Odg: Titlovi
    Mix jos jednom hvala, ova tvoja upustva su mi pomogla i przenje DVD-a je uspjelo samo ima par greskica:
    - titl mi stoji prenisko (stavio sam standarde margne kao sto su na programu)
    - na titlu nema nekih slova koja su tipicna za nas jezik kao npr. cŤcc‘š itd.
    - kod ubacivanja titla pod "Character set" nisam moga da nadjem "MacCroatian" kao sto si ti meni u upustvu stavio
    (4.Klikni na Edit i tu si namjesti font i pod Language odaberi Croatian, a pod Char. Set MacCroatian)
    - Titl mi malo kasni pa neznam dali se to moze kako promijeniti.
    Zamolio bih sve one koji mi mogu pomoci u ovom problemu da se obrate ovdje na ovom sajtu.
    Puno hvala,
    Mrki_NL
Pravila pisanja poruke
  • Ne možete otvoriti novu temu
  • Ne možete ostavljati odgovore
  • Ne možete stavljati privitke
  • Ne možete uređivati svoje poruke
Trenutno vrijeme na forumu: 18:26.
Copyright © by CroSatelite.com
