Stranica 4 od 5 PrvaPrva ... 2345 PosljednjePosljednje
Prikaz rezultata str. 31/43
  1. #31
    Urednik
    Član od
    Dec 2011
    Lokacija
    Slovakia-komarno
    Poruke
    521
    90
    Pohvaljen 182 puta u
    100 postova
    Nemesis 2.5 106r2 next step
    Updated 09.03.2012-15:00
    • All updates until 105r4 are included
    • Added developper mode for skinner Thank's @skaman)
    • Added Suppprt for Skins on external device Now you can install skin on, USB/CF/HDD/eSATA devices (Only skins vithout python code modification)
    • Added Autodiscover Picon Discover on: Flash, USB/CF/HDD/eSATA devices and Network Mountpoint
    • Added Autodiscover swap file Discover on: USB/CF/HDD/eSATA devices
    • Added Autodiscover epg.dat file Discover on: Flash, USB/CF/HDD/eSATA devices and Network Mountpoint
    • Added device selection for Picon installation You can install Picon on: Flash, USB/CF/HDD/eSATA devices and Network Mountpoint
    • Removed Picon Provider, System e Satellite from image
      Now you can install it from Blu Panel->Addons
    • Updated italian CVS translation using german locale as reference (Thank's @blu8)
    • Updated Nemesis Panel italian translation(Thank's @blu8)
    • Updated enigma2-plugins
  2. #32
    Član od
    Feb 2009
    Poruke
    11,196
    9,635
    Pohvaljen 13,075 puta u
    4,942 postova
    Nemesis 2.5 106r6 next step
    Updated 13.03.2012-14:00
    •All updates until 105r4 are included
    •Move to 2.6 version
    •Update Enigma2 to 3.2.2 (20120309)
    •Update Bootlogo for version 2.6 (thanks @XPlanet)
    •Replaced the eXcort Lux default skin, with the new Nemesis Black Skin by Mmark (thanks @mmark & Stardust)
    •Added possibility to enable/disable Pig Widget on Skin
    •Added developer mode for skinner (Thank's @skaman)
    •Added Suppprt for Skins on external device
    (At the moment 0nly skins without Python code modification)
    •Added Autodiscover Picon
    •Added Autodiscover swap file
    •Added Autodiscover epg.dat file
    •Added device selection for Picon installation
    •Removed Picon Provider, System e Satellite from image
    Now you can install it from Blue Panel->Addons
    •Updated italian CVS translation using german locale as reference (Thank's @blu8)
    •Updated Nemesis Panel italian translation(Thank's @blu8)
    •Updated enigma2-plugins
    Dreambox 500hd
    Dreambox 800se
    Samsung Dsr9500viaci(2x)
    Neotionbox 501
    Triax 90-motor strongHH120
    Tanjur110-motor sti-na testu
    Lg-plasma-107
  3. #33
    Član od
    Feb 2009
    Poruke
    11,196
    9,635
    4,942 postova
    New Nemesis 2.6 106r8 next step
    Updated 16.03.2012-11:00
    • Move to 2.6 version
    • Added possibility to disable HDD as a device for epg.dat, swap files and skins
    • Added possibility to remove HDD on Picon search path
    • Update CrossEPG to use new Autodiscover EPG (Only for Nemesis Images)
    • Update Enigma2 to 3.2.2 (20120309)
    • Update Bootlogo for version 2.6 (thanks @XPlanet)
    • Replaced the eXcort Lux default skin, with the new Nemesis Black Skin by mmark (thanks @mmark & Stardust)
    • Added possibility to enable/disable Pig Widget on Skin Blue->Yellow->Setup InfoBar OSD->Enable Pig Widget on skin
    • Added developer mode for skinner (Thank's @skaman)
    Dreambox 500hd
    Dreambox 800se
    Neotionbox 501
    Lg-plasma-107
  4. #34
    Član od
    Feb 2009
    Poruke
    11,196
    9,635
    4,942 postova
    NEMESIS 2.5 105r4 Dual Enigma on-line, next step 107r0
    New Nemesis 2.6 107r0 next step
    Updated 22.03.2012-11:00
    •Update dreambox-dvb-modules to 20120322 for 500hd, 800se, 7020hd and 8000
    •Update Enigma2 to 3.2.2 (20120321)
    •Added possibility to disable HDD as a device for epg.dat, swap files and skins
    •Added possibility to remove HDD on Picon search path
    •Update CrossEPG to use new Autodiscover EPG (Only for Nemesis Images)
    •Replaced the eXcort Lux default skin, with the new Nemesis Black Skin by mmark (thanks @mmark & Stardust)
    •Added possibility to enable/disable Pig Widget on SkinBlue->Yellow->Setup InfoBar OSD->Enable Pig Widget on skin
    •Added Suppprt for Skins on external deviceNow you can install skin on, USB/CF/HDD/eSATA devices
    Dreambox 500hd
    Dreambox 800se
    Neotionbox 501
    Lg-plasma-107
  5. #35
    Član od
    Feb 2009
    Poruke
    11,196
    9,635
    4,942 postova
    NEMESIS 2.6 107r2 Dual Enigma coming soon!
    New Nemesis 2.6 107r2
    Updated 27.03.2012-13:00
    •Rewrite device info panel, now are also displayed the network devices
    •Updated full german locale translation (thanks @bigstar2005)
    Dreambox 500hd
    Dreambox 800se
    Neotionbox 501
    Lg-plasma-107
  6. #36
    Urednik
    Član od
    Mar 2011
    Lokacija
    N.Marof
    Poruke
    5,669
    3,132
    Pohvaljen 3,972 puta u
    1,899 postova
    NEMESIS 2.6 107r4 Dual Enigma coming soon!
    New Nemesis 2.6 107r4
    Updated 28.03.2012-09:00
    Update dreambox-dvb-modules to 20120328 fot 800se
    Update dreambox-dvb-modules to 20120322 for 500hd, 7020hd and 8000
    Update Enigma2 to 3.2.2 (20120327)
    Move to 2.6 version
    Blue->Yellow->Setup Skin->Enable Pig Widget on skin
    <!-- / message --><!-- sig -->
  7. #37
    Urednik
    Član od
    Mar 2011
    Lokacija
    N.Marof
    Poruke
    5,669
    3,132
    1,899 postova
    Nemesis 2.6 107r5
    Updated 29.03.2012-13:00
    Move to 2.6 version
    Are you ready for new NEMESIS 2.6 Dual Enigma?
    Attention read carrefully!
    to do before upgrade to 107r5!!!!
    Remove all Skins installed from Addons and reboot with de default skin
    the old skins are no more compliant with the 107r5
    proceed with the upgrade on-line
    Three hours from now !!!!
  8. #38
    Član od
    Feb 2009
    Poruke
    11,196
    9,635
    4,942 postova
    <center> Are you ready for new NEMESIS 2.6 Dual Enigma?
    Nemesis 2.6 Dual Enigma is here!
    </center>
    • Remove all Skins installed from Addons and reboot with de default skin
    • proceed with the upgrade on-line
    Nemesis 2.6 107r5
    • Rewrite device info panel, now are also displayed the network devices
    • Update dreambox-dvb-modules to 20120328 fot 800se
    • Update dreambox-dvb-modules to 20120322 for 500hd, 7020hd and 8000
    • Update Enigma2 to 3.2.2 (20120327)
    • Added possibility to enable/disable Pig Widget on Skin Blue->Yellow->Setup Skin->Enable Pig Widget on skin
    • Updated full german locale translation (thanks @bigstar2005)
    Download:
    http://uploaded.to/file/0u12xdul
    Dreambox 500hd
    Dreambox 800se
    Neotionbox 501
    Lg-plasma-107
  9. Sljedeći član se zahvalio beli1910 na ovoj poruci:
    križ@r (24-07-2012)
  10. #39
    Urednik
    Član od
    Mar 2011
    Lokacija
    N.Marof
    Poruke
    5,669
    3,132
    1,899 postova
    NEMESIS 2.6 107r5 Dual Enigma, next step 108
    Updated 17.04.2012-09:00
    Nemesis 2.6 108r2, next step
    All updates until 107r5 are included
    Fix download EPG via green panel
    Update plugin CrossEPG
    Fix crash on skin selector
    Small fixes on skin Black
    Add check for developper mode on Blue Panel
    Improve scripts Remove Picon ad Remove Epg files
    Fix remove OpenVPN log
  11. #40
    Urednik
    Član od
    Dec 2009
    Lokacija
    Užice
    Poruke
    2,329
    2,438
    Pohvaljen 2,804 puta u
    959 postova
    Nemesis 2.6 108r3, next step
    Updated 18.04.2012-13:00
    Update PCSC-Lite to 1.8.3Update ccid to 1.4.6
    Update kernel to InitramFS 3.0 for all machines (thanks @OoZooN and gutemine)
    Fix download EPG via Green PanelUpdate plugin CrossEPG
    Fix occasional crash on Skin Selector
    Small fixes on Skin Black
    Added check if you are on developer mode on Blue Panel
    Improve scripts Remove Picon and Remove Epg files
    H3Y 3V3RY0N3 1 C4N H4CK B3C4U53 1 KN0W UN1X
Pravila pisanja poruke
  • Ne možete otvoriti novu temu
  • Ne možete ostavljati odgovore
  • Ne možete stavljati privitke
  • Ne možete uređivati svoje poruke
Trenutno vrijeme na forumu: 07:12.
Copyright © by CroSatelite.com
